I need help with Javascript Node to Data Transformation
Hey guys, how are you?
I need some solution so that I can add a comma “,” two decimal places in the opposite direction.
It turns out that the value of “Invoicing” that I get from the webhook is not separated by commas. Instead of seeing “57.00”, it comes with “5700” and I need to format it to add it to Sheets.
I believe that the best way to solve this is to use javascript with a custom code, but I don’t understand this language. can you help me?
Follow my flow below:
Prints:
Try with dividing it with 100.
{{ $json["body"]["transaction"]["total_price"] / 100 }}
Thanks bro! Now it worked.
