I’ve made good progress on my enrichment workflow, all the APIs are working etc… but I have a few small bugs. (Knowing that I use the Open Source version of n8n)
I would like you to tell me in the structure what could be simplified or improved because I have the impression that ChatGPT has made everything more complex for me
Then I would like that in my Loop my Json elements linked to my Google Sheet are all accessible at all times, that is to say that we can call {{ $json.LinkedIn }}, {{ $json.Mail }} etc… at any time in the Loop (This is my biggest problem) knowing that I have the impression that the Http and Update overwrite this data and therefore that I never have access to it again even though it is essential data to make my APIs work
I would like to have a csv rendering that does not bug, if you look at the screen just below the second enrichment from Louis overwrote that of Célian and came to this line there when it should not have.
I am attaching a photo of the scenario and the JSON so that it can help you understand my mistakes, thank you in advance because it is very important for me
Voici le Json : {
“name”: “Enrichment Sales Navigator”,
“nodes”: [
“parameters”: {
“operation”: “update”,
“documentId”: {
“__rl”: true,
“value”: “={{ $node[\“Create spreadsheet2\”].json.spreadsheetId }}”,
“mode”: “id”
“sheetName”: {
“__rl”: true,
“value”: “={{ $node[\“Create spreadsheet2\”].json.sheets[0].properties.sheetId }}”,
“mode”: “id”
“columns”: {
“mappingMode”: “defineBelow”,
“value”: {
“Mail”: “={{ $json.Mail }}”,
“Certainty”: “={{ $json.Certainty }}”,
“MXRecords”: “={{ $json.MXRecords }}”,
“MXProvider”: “={{ $json.MXProvider }}”,
“rowIndex”: “={{ $json.rowIndex }}”
“matchingColumns”: [
“rowIndex”
“schema”: [
“id”: “Name”,
“displayName”: “Name”,
“required”: false,
“defaultMatch”: false,
“display”: true,
“type”: “string”,
“canBeUsedToMatch”: true,
“removed”: true
“id”: “Second Name”,
“displayName”: “Second Name”,
“required”: false,
“display”: true,
“type”: “string”,
“removed”: true
“id”: “LinkedIn”,
“displayName”: “LinkedIn”,
“required”: false,
“display”: true,
“type”: “string”,
“removed”: true
“id”: “Mail”,
“displayName”: “Mail”,
“required”: false,
“display”: true,
“type”: “string”,
“id”: “Number”,
“displayName”: “Number”,
“required”: false,
“display”: true,
“type”: “string”,
“removed”: true
“id”: “site”,
“displayName”: “site”,
“required”: false,
“display”: true,
“type”: “string”,
“removed”: true
“id”: “Certainty”,
“displayName”: “Certainty”,
“required”: false,
“display”: true,
“type”: “string”,
“id”: “MXRecords”,
“displayName”: “MXRecords”,
“required”: false,
“display”: true,
“type”: “string”,
“id”: “MXProvider”,
“displayName”: “MXProvider”,
“required”: false,
“display”: true,
“type”: “string”,
“id”: “QualityMail”,
“displayName”: “QualityMail”,
“required”: false,
“display”: true,
“type”: “string”,
“removed”: true
“id”: “ResultMail”,
“displayName”: “ResultMail”,
“required”: false,
“display”: true,
“type”: “string”,
“removed”: true
“id”: “rowIndex”,
“displayName”: “rowIndex”,
“required”: false,
“display”: true,
“type”: “string”,
“removed”: false
“id”: “row_number”,
“displayName”: “row_number”,
“required”: false,
“display”: true,
“type”: “number”,
“readOnly”: true,
“removed”: true
“attemptToConvertTypes”: false,
“convertFieldsToString”: false
“options”: {}
“type”: “n8n-nodes-base.googleSheets”,
“typeVersion”: 4.6,
“position”: [
1808,
1600
“id”: “dd3628de-6a0a-49c8-bf2a-20840885ff65”,
“name”: “Update row in sheet”,
“alwaysOutputData”: true,
“credentials”: {
“googleSheetsOAuth2Api”: {
“id”: “5vWzdQgZW1Nku6Ke”,
“name”: “Google Sheets account”
“parameters”: {
“documentId”: {
“__rl”: true,
“mode”: “id”
“sheetName”: {
“__rl”: true,
“mode”: “id”
“columns”: {
“value”: {
“ResultMail”: “={{ $json.ResultMail }}”,
“QualityMail”: “={{ $json.QualityMail }}”,
“rowIndex”
“schema”: [
“id”: “Name”,
“required”: false,
“display”: true,
“type”: “string”,
“removed”: true
“required”: false,
“display”: true,
“type”: “string”,
“removed”: true
“id”: “LinkedIn”,
“required”: false,
“display”: true,
“type”: “string”,
“removed”: true
“id”: “Mail”,
“required”: false,
“display”: true,
“type”: “string”,
“removed”: true
“id”: “Number”,
“required”: false,
“display”: true,
“type”: “string”,
“removed”: true
“id”: “site”,
“required”: false,
“display”: true,
“type”: “string”,
“removed”: true
“id”: “Certainty”,
“required”: false,
“display”: true,
“type”: “string”,
“removed”: true
“id”: “MXRecords”,
“required”: false,
“display”: true,
“type”: “string”,
“removed”: true
“id”: “MXProvider”,
“required”: false,
“display”: true,
“type”: “string”,
“removed”: true
“required”: false,
“display”: true,
“type”: “string”,
“removed”: false
“id”: “ResultMail”,
“required”: false,
“display”: true,
“type”: “string”,
“removed”: false
“id”: “rowIndex”,
“required”: false,
“display”: true,
“type”: “string”,
“removed”: false
“id”: “row_number”,
“required”: false,
“display”: true,
“type”: “number”,
“readOnly”: true,
“removed”: true
“options”: {}
“typeVersion”: 4.6,
“position”: [
3744,
1280
“id”: “cbba36d3-4c2d-486e-8f5b-2739841e2c2d”,
“name”: “Update row in sheet1”,
“credentials”: {
“parameters”: {
“documentId”: {
“__rl”: true,
“mode”: “id”
“sheetName”: {
“__rl”: true,
“mode”: “id”
“columns”: {
“value”: {},
“matchingColumns”: ,
“schema”: ,
“options”: {}
“typeVersion”: 4.6,
“position”: [
2064,
1840
“id”: “f86fcf9c-d070-4de1-83c2-36e60c24c630”,
“name”: “Update row in sheet2”,
“credentials”: {
“parameters”: {
“conditions”: {
“options”: {
“caseSensitive”: true,
“leftValue”: “”,
“typeValidation”: “strict”,
“version”: 2
“conditions”: [
“id”: “d97f4fd6-8642-4983-8b8c-664fdceefbd5”,
“leftValue”: “={{ $json.Number }}”,
“rightValue”: “”,
“operator”: {
“type”: “string”,
“operation”: “notEmpty”,
“singleValue”: true
“combinator”: “and”
“options”: {}
“type”: “n8n-nodes-base.if”,
“typeVersion”: 2.2,
“position”: [
4672,
1008
“id”: “c299c197-2c00-486e-a732-c2f9821e0ae9”,
“name”: “If4”
“parameters”: {
“method”: “POST”,
“url”: “https://api.zeliq.com/api/contact/enrich/phone”,
“sendHeaders”: true,
“headerParameters”: {
“parameters”: [
“name”: “accept”,
“value”: “application/json”
“name”: “x-api-key”,
“value”: “sk-723efa2d8c18422b9a2aa1cea704b400fddb95e821383083”
“sendBody”: true,
“bodyParameters”: {
“parameters”: [
“name”: “linkedin_url”,
“value”: “={{ $json.LinkedIn }}”
“name”: “email”,
“value”: “={{ $json.Mail }}”
“options”: {}
“typeVersion”: 4.2,
“position”: [
4928,
1008
“id”: “b1abb5fd-f29a-4a83-aa88-29f22f00389f”,
“name”: “HTTP Request4”
“parameters”: {
“documentId”: {
“__rl”: true,
“mode”: “id”
“sheetName”: {
“__rl”: true,
“mode”: “id”
“columns”: {
“value”: {
“rowIndex”: “={{ $json.rowIndex }}”,
“Number”: “={{ $json.Number }}”
“rowIndex”
“schema”: [
“id”: “Name”,
“required”: false,
“display”: true,
“type”: “string”,
“removed”: true
“required”: false,
“display”: true,
“type”: “string”,
“removed”: true
“id”: “LinkedIn”,
“required”: false,
“display”: true,
“type”: “string”,
“removed”: true
“id”: “Mail”,
“required”: false,
“display”: true,
“type”: “string”,
“removed”: true
“id”: “Number”,
“required”: false,
“display”: true,
“type”: “string”,
“id”: “site”,
“required”: false,
“display”: true,
“type”: “string”,
“removed”: true
“id”: “Certainty”,
“required”: false,
“display”: true,
“type”: “string”,
“removed”: true
“id”: “MXRecords”,
“required”: false,
“display”: true,
“type”: “string”,
“removed”: true
“id”: “MXProvider”,
“required”: false,
“display”: true,
“type”: “string”,
“removed”: true
“required”: false,
“display”: true,
“type”: “string”,
“removed”: true
“id”: “ResultMail”,
“required”: false,
“display”: true,
“type”: “string”,
“removed”: true
“id”: “rowIndex”,
“required”: false,
“display”: true,
“type”: “string”,
“removed”: false
“id”: “row_number”,
“required”: false,
“display”: true,
“type”: “number”,
“readOnly”: true,
“removed”: true
“options”: {}
“typeVersion”: 4.6,
“position”: [
4736,
1312
“id”: “e2966592-b81a-4730-bc83-0ad684826b27”,
“name”: “Update row in sheet3”,
“credentials”: {
“parameters”: {
“content”: “## Debounce Email”,
“height”: 864,
“width”: 880,
“color”: 4
“type”: “n8n-nodes-base.stickyNote”,
“position”: [
3264,
928
“typeVersion”: 1,
“id”: “19459f15-165a-4569-afb6-99e908c969c0”,
“name”: “Sticky Note4”
“parameters”: {
“content”: “## Enrichment Phone\n”,
“height”: 832,
“width”: 752,
“color”: 5
“position”: [
4640,
928
“typeVersion”: 1,
“id”: “f5b7fcfc-bc6e-47c3-b381-8018a4c441ea”,
“name”: “Sticky Note5”
“parameters”: {
“operation”: “download”,
“fileId”: {
“__rl”: true,
“value”: “={{ $items(\“Create spreadsheet2\”,0)[0].json.spreadsheetId }}”,
“mode”: “id”
“options”: {
“googleFileConversion”: {
“conversion”: {}
“fileName”: “Fichier Enrichie”
“type”: “n8n-nodes-base.googleDrive”,
“typeVersion”: 3,
“position”: [
2656,
480
“id”: “6e0bddde-452e-4e0f-8047-908e918559c4”,
“name”: “Download file”,
“credentials”: {
“googleDriveOAuth2Api”: {
“id”: “LSpLUCOHntGdaaAU”,
“name”: “Google Drive account”
“parameters”: {
“formTitle”: “Drop your LinkedIn Extract”,
“formFields”: {
“values”: [
“fieldLabel”: “Excel”,
“fieldType”: “file”,
“acceptFileTypes”: “.xlsx, .csv”,
“requiredField”: true
“options”: {}
“type”: “n8n-nodes-base.formTrigger”,
“typeVersion”: 2.2,
“position”: [
-592,
1312
“id”: “5ec790aa-36e6-4fe7-8098-978bffa6cdc3”,
“name”: “On form submission1”,
“webhookId”: “3f906715-51c1-47df-9ba5-ed5cf3412c1a”
“parameters”: {
“conditions”: {
“options”: {
“leftValue”: “”,
“version”: 2
“conditions”: [
“id”: “acd3b363-7378-4386-9e14-691001f76070”,
“leftValue”: “={{ $json.Excel[0].filename }}”,
“rightValue”: “.csv”,
“operator”: {
“type”: “string”,
“operation”: “contains”
“combinator”: “and”
“options”: {}
“typeVersion”: 2.2,
“position”: [
-384,
1312
“id”: “02f3eef0-3749-45ed-aebd-aaacd6aef425”,
“name”: “If5”
“parameters”: {
“binaryPropertyName”: “Excel”,
“options”: {
“headerRow”: true,
“includeEmptyCells”: true
“type”: “n8n-nodes-base.extractFromFile”,
“typeVersion”: 1,
“position”: [
-192,
1264
“id”: “4c55e4a3-ce88-4479-95c3-b13e7c64e947”,
“name”: “Extract from File2”
“parameters”: {
“operation”: “xlsx”,
“options”: {
“headerRow”: true,
“typeVersion”: 1,
“position”: [
-192,
1392
“id”: “9936f5e4-9590-485b-b3a7-ddb430c5112b”,
“name”: “Extract from File3”
“parameters”: {
“method”: “POST”,
“url”: “https://app.icypeas.com/api/email-search”,
“parameters”: [
“name”: “Authorization”,
“value”: “73308a8701814947b8e5661cd736a9bc3dafd79888aa4ec4be5a74788608385b”
“sendBody”: true,
“bodyParameters”: {
“parameters”: [
“name”: “firstname”,
“value”: “={{ $json.Name }}”
“name”: “lastname”,
“value”: “={{ $json[\“Second Name\”] }}”
“name”: “domainOrCompany”,
“value”: “={{ $json.site }}”
“options”: {}
“typeVersion”: 4.2,
“position”: [
1840,
1312
“id”: “7a6dc34b-87c8-410b-b8cc-04735df6fe05”,
“name”: “HTTP Request5”
“parameters”: {
“amount”: 10
“type”: “n8n-nodes-base.wait”,
“typeVersion”: 1.1,
“position”: [
2016,
1312
“id”: “7358a671-eb78-40ba-8edf-0b0282ac6e99”,
“name”: “Wait”,
“webhookId”: “5ae14bfd-9c97-4b76-a22e-e4df6426a672”
“parameters”: {
“method”: “POST”,
“url”: “https://app.icypeas.com/api/bulk-single-searchs/read”,
“parameters”: [
“sendBody”: true,
“bodyParameters”: {
“parameters”: [
“name”: “id”,
“value”: “={{ $json.item._id }}”
“options”: {}
“typeVersion”: 4.2,
“position”: [
2208,
1312
“id”: “1986da17-ee60-458f-b35d-f53fd1064841”,
“name”: “HTTP Request6”
“parameters”: {
“method”: “POST”,
“url”: “https://app.findymail.com/api/search/linkedin”,
“parameters”: [
“value”: “Bearer eLXSGZceRlhe9wT7xTjT9KNapRjHTvAJlQEk4P2r000a2653”
“sendBody”: true,
“specifyBody”: “json”,
“jsonBody”: “={\n \“linkedin_url\”: \”{{ $json.LinkedIn }}\“,\n \“webhook_url\”: null\n}”,
“options”: {}
“typeVersion”: 4.2,
“position”: [
1808,
1840
“id”: “52d5724e-edbd-418a-acc3-749427fd934f”,
“name”: “HTTP Request7”
“parameters”: {
“url”: “https://api.millionverifier.com/api/v3”,
“sendQuery”: true,
“queryParameters”: {
“parameters”: [
“name”: “api”,
“value”: “XOsXdRHXZ4JEAAVmJXWZyi5r4”
“name”: “email”,
“name”: “timeout”,
“value”: “10”
“options”: {
“redirect”: {
“redirect”: {}
“typeVersion”: 4.2,
“position”: [
3760,
1024
“id”: “9f2c0230-c4da-4793-85f1-2d81a5d4fd98”,
“name”: “HTTP Request8”
“parameters”: {
“options”: {}
“type”: “n8n-nodes-base.splitInBatches”,
“typeVersion”: 3,
“position”: [
1808,
1024
“id”: “683d6c85-35e5-4a29-b298-03530ab2cd6a”,
“name”: “Loop Over Items3”,
“alwaysOutputData”: false
“parameters”: {
“conditions”: {
“options”: {
“leftValue”: “”,
“version”: 2
“conditions”: [
“id”: “07c642cd-7ad1-40d1-9f1c-0d86ae5f7fa6”,
“leftValue”: “={{ $json.Mail }}”,
“rightValue”: “”,
“operator”: {
“type”: “string”,
“singleValue”: true
“combinator”: “and”
“options”: {}
“typeVersion”: 2.2,
“position”: [
2272,
1040
“id”: “67ed3916-7c7c-4c80-8814-fd57e556b0d1”,
“name”: “If6”
“parameters”: {
“conditions”: {
“options”: {
“leftValue”: “”,
“version”: 2
“conditions”: [
“rightValue”: “”,
“operator”: {
“type”: “string”,
“operation”: “empty”,
“singleValue”: true
“combinator”: “and”
“options”: {}
“typeVersion”: 2.2,
“position”: [
2816,
1312
“id”: “b84c04ef-59ea-4e72-ac24-2f0c7488e130”,
“name”: “If7”
“parameters”: {
“resource”: “spreadsheet”,
“title”: "Fichier Enrich ",
“sheetsUi”: {
“sheetValues”: [
“title”: “=Fichier Enrichie {{ $json.Excel[0].filename }}”
“options”: {}
“typeVersion”: 4.6,
“position”: [
384,
1312
“id”: “cc4e1618-e26f-4df4-b91a-edc0795fa011”,
“name”: “Create spreadsheet2”,
“credentials”: {
“parameters”: {
“operation”: “append”,
“documentId”: {
“__rl”: true,
“value”: “={{ $(‘Create spreadsheet2’).item.json.spreadsheetUrl }}”,
“mode”: “url”
“sheetName”: {
“__rl”: true,
“value”: “={{ $(‘Create spreadsheet2’).item.json.sheets[0].properties.sheetId }}”,
“mode”: “id”
“columns”: {
“mappingMode”: “autoMapInputData”,
“value”: {},
“schema”: [
“id”: “client_name”,
“displayName”: “client_name”,
“required”: false,
“display”: true,
“type”: “string”,
“removed”: false
“id”: “period_start”,
“displayName”: “period_start”,
“required”: false,
“display”: true,
“type”: “string”,
“removed”: false
“id”: “period_end”,
“displayName”: “period_end”,
“required”: false,
“display”: true,
“type”: “string”,
“removed”: false
“id”: “pipelines”,
“displayName”: “pipelines”,
“required”: false,
“display”: true,
“type”: “string”,
“removed”: false
“id”: “event_limit”,
“displayName”: “event_limit”,
“required”: false,
“display”: true,
“type”: “string”,
“removed”: false
“id”: “actual_event_volume”,
“displayName”: “actual_event_volume”,
“required”: false,
“display”: true,
“type”: “string”,
“removed”: false
“id”: “events_over_limit”,
“displayName”: “events_over_limit”,
“required”: false,
“display”: true,
“type”: “string”,
“removed”: false
“id”: “overage_multiplier”,
“displayName”: “overage_multiplier”,
“required”: false,
“display”: true,
“type”: “string”,
“removed”: false
“id”: “event_price_per_month”,
“displayName”: “event_price_per_month”,
“required”: false,
“display”: true,
“type”: “string”,
“removed”: false
“id”: “overage_cost”,
“displayName”: “overage_cost”,
“required”: false,
“display”: true,
“type”: “string”,
“removed”: false
“id”: “currency”,
“displayName”: “currency”,
“required”: false,
“display”: true,
“type”: “string”,
“removed”: false
“id”: “status”,
“displayName”: “status”,
“required”: false,
“display”: true,
“type”: “string”,
“removed”: false
“id”: “note”,
“displayName”: “note”,
“required”: false,
“display”: true,
“type”: “string”,
“removed”: false
“options”: {
“useAppend”: true
“typeVersion”: 4.6,
“position”: [
768,
1312
“id”: “4b59b9d7-25c2-4223-b8fb-5ef68c35c639”,
“name”: “Append row in sheet4”,
“credentials”: {
