I need help with Piperun's HTTP Request
Hi everyone, I’m having trouble using the Node.js HTTP request to Piperun. It says my credentials are incorrect, but I’m using the exact token that Piperun provided. What could be the problem?
can you please screenshot the workflow, the settings and the error please? it might be the way you put your credentials, did you follow the documentations of Piperun API?
