I need to read a mailbox with POP and IMAP and used the IMAP Trigger node from n8n
Guys, I need to read a mailbox with POP and IMAP and used the IMAP Trigger node from n8n. The problem is that this node only works with new emails that arrive after I activate it and then stops, working only once. I want it to load all unread emails from the mailbox and for the workflow to restart after saving the message data in the Supabase database. Can anyone help me?
  • n8n version: 0.216.2
  • Running n8n via desktop app):
  • Operating system: Win 11
hello @Roberto_Oliveira
I think there is no node to read emails from general mailbox. You can try the HTTP node if the service can provide an API, or Gmail/Outlook node if you are using corresponding service
