I need your help in activation key
I need help solving an issue with my n8n setup. I downloaded n8n on my PC using Node.js, but during the setup I accidentally skipped the option to send the API activation to my email.
How can I get the activation link again?
Thanks in advance for your support!
you can go there, setting - usage and Plan
Hey @Samar_Samy hope all is good. Welcome to the community.
If you go to Settings - Usage and Plan, what do you see there?
I skipped the step where they send me the activation key to my email.
Could you please guide me on how to request or resend the activation email?
Unfortunately, I skipped the step where they send me the activation key to my email.
what do you see in there
in setting - usage and Plan
Thank you so much🙏🏻 it solved when I clicked on unlock then send me activation key
For sure men, if you dont mind me asking, do you by accident clicking your own reply as the solution?
Yes, I edit that, thanks
You can’t do it, but maybe @bartv can help with that
Hi there bartv, if you are seeing this, as you can see the owner of the post has accidentally mark his own question as the solution, if you can kindly move tht into one of mine that would be great, thank you!
It’s done.
