I want Join N8N with Azure AI Search and build a RAG. how can i vectorize querry and pull data from VectordB
I want to Build a RAG with Azure AI Search
Not able to find appropriate tools to vectorize querry
Hey Aditya! If you’re trying to build a RAG system with Azure AI Search in n8n, here’s the general path:
  1. How to vectorize the query:
    n8n doesn’t have a native Azure embedding node yet, but you can use an HTTP Request Node to hit your embedding model endpoint in Azure OpenAI (or any compatible embedding model).
    For example: text-embedding-ada-002, if that’s available in your setup.
  2. Pull data from Azure AI Search:
    After generating the vector, use another HTTP Request Node to query your Azure AI Search index, passing the vector like this:
“vector”: [0.123, 0.456, …],
“top”: 5,
“fields”: “content”
  1. Stitch it all together:
    Capture the user question
    Generate the embedding
    Search the index
    Combine the context with the query
    Send it to the model (like ChatGPT or GPT-4) to generate the final answer
