Below mentioned is the error message
ERROR: The resource you are requesting could not be found
404 - “\n\n\t\n\t\t\n\t\t\n\t\t\tSBV Hub\t\t\n\t\t\n\t\t\t\t\n\t\t\t\t\n\t\t\n\t\t\n\t\t\n\t\t\n\t\t\n\n\n\n\t\t\n\n\n\n\n\n\n\t\t\t\n\t\n\t\t\n\t\n\t\t\n\t\t\tThis application requires JavaScript for correct operation. Please enable JavaScript and reload the page.\t\t\n\t\n\n\t\t\t\t\t\n\t\t\t\t\t\n\t\t\t\t\t\n\t\t\t\t\n\t\t\t\n\t\t\t\t\t\t\t\t\t\n\t\t\t\t\t\t\n\t\t\t\t\t\t\t\n\t\t\t\t\t\t\n\t\t\t\t\t\n\t\t\t\t\t\t\t\t\n\t\t\t\t\t\n\t\t\t\t\t\tSBV Hub\t\t\t\t\t\n\t\t\t\t\t\n\tError\n\t\n\t\t\t\n\t\t\t
404
\n\t\t\t\t\t\t\t
The page could not be found on the server.
\n\t\t\t\t\t\n\t\t\n\n\t\t\t\t\n\t\t\t\n\t\t\n\t\t\n\t\t\t
\n\t\t\t\tSBV Hub – Sri Balaji Vidyapeeth Hub\t\t\t
\n\t\t\n\t\n\n” - SBV Hub This application requires JavaScript for correct operation. Please enable JavaScript and reload the page. SBV Hub Error
404
I have installed filemaker pro in our server, we created a application and want to export the file to the nextcloud.
