If n8n call a subworkflow will i be billed twice or is it 1 excecution?
if n8n call a subworkflow will i be billed twice or is it 1 excecution?
Hey @Sumon,
Good question!
From my experience, calling a subworkflow from a main workflow in n8n does not result in double billing.
Here’s why:
  • I’ve created several workflows where the main workflow calls one or more subworkflows.
  • These subworkflows are not set to active…they’re only triggered from within the main workflow.
  • Since only the main workflow is active and triggered externally, n8n treats it as a single execution.
So in short, you’ll only be billed for the main workflow execution, not for each subworkflow it calls.
Hope that clears it up!
