If statement returns false when it should be true? Re-creating the statement gives same result
n8n version: 0.212.1
Database (default: SQLite): default
n8n EXECUTIONS_PROCESS setting (default: own, main): main
Running n8n via (Docker, npm, n8n cloud, desktop app): docker
Operating system: ubuntu
hello,
how can i fix this? it keeps doing it even if i re-create the if statement:
Thank you
Jon
November 29, 2023, 10:17am
2
Hey @xewonder ,
Can you share a workflow that reproduces this? I have just given it a go with a quick test and it appears to be working as expected.
The workflow I created can be found below.
Something I would maybe do is try changing your expression to use the newer {{ $('Get Trigger Details').item.json.geofence_id }} syntax which would work better if you are using multiple items.
Hi @Jon
I tried as expression or as fixed value. Keeps going to false!
{{ parseInt($node[‘Get Trigger Details’].json[‘geofence_id’] ) }}
use parseint() , which will force the value into numeric format
Hi @lightcom ,
If you check the screenshot in my first post, you will notice that i was already using phraseint().
I will dig a bit further.
Yeah checked, that’s strange
Jon
December 17, 2023, 12:37pm
7
Are you able to provide the workflow and data that reproduces this? I was not able to reproduce it so I would need more information to work it out.
