I am building my first more complex workflow and I am running into a problem regarding two IF statements at the end of my workflow.
What I am doing with this workflow is validating email addresses that where entered into my crm (Pipedrive).
I am passing along the email address that I have or find, to different email services and validating them through Zerobounce. If a Zerobounce validation passes as valid, the workflow is done. If that doesn’t happen I want to check at the end what the validation was of the email services that I use to find email addresses. If those have an acceptable validation I will enter them into Pipedrive as well.
This is my workflow:
The problem now, is that these checks at the end (the two if statements) are never true. But I don’t think that is right. I know this as multiple addresses are found, and then not verified by zerobounce. They should end up at the if statements and evaluate to true a couple of times. I think there is something wrong with the data that is passed to the if statement nodes:
I have tried debugging this problem for two hours now, but I can’t figure out what the problem is.
Any idea what the problem is?
None
- n8n version: 0.219.1
- Running n8n via [Docker, npm, n8n.cloud, desktop app]: Docker
