I have a workflow that gives me a different outcome when executing the node than it does when executing the whole flow despite the data point used for the if check remaining the same
- n8n version:
- Database (default: SQLite):
- Operating system:
n8n v 0.233.1
OS Windows
Welcome to the community!
That version is very out of date. Please update to see if that solves the issue.
If it doesn’t, then please share your workflow by coping it and pasting it in the code block provided by the </> button in the comment editor.
Please also share a sample of the JSON that is the input for
