IMAP node and non-UTF encoding (iso-8859-2)
I’m trying to create an email parser for notifications. The problem is, that the notifications are send in HTML-only and they are using ISO-8859-2 encoding.
When I execute IMAP node with Resolved/Simple formats, here’s what I see in html property:
E-mail zostaďż˝ wygenerowany automatycznie, prosimy na niego nie odpowiadaďż˝.
With RAW I get:
E-mail zosta� wygenerowany automatycznie, prosimy na niego nie odpowiada�.
(RAW also mentions encoding: This is an S/MIME signed message ------271FA8CCD25A514291379894969B4570 Content-Type: text/html; charset=iso-8859-2 Content-Transfer-Encoding: 8bit Date: Thu, 22 Jun 2023 17:19:36 +0200)
In order to properly work with this, I need to convert to UTF-8:
E-mail został wygenerowany automatycznie, prosimy na niego nie odpowiadać.
How can I achieve that? I tried converting it with jschardet + iconv-lite, but when the data gets to the Code node, it has already become ASCII (that’s at least how jschardet detects it as)
I tried encoding this as following:
const iconv = require('iconv-lite');
let buffer = Buffer.from($json.raw, 'binary');
let decodedData = iconv.decode(buffer, 'ISO-8859-2');
console.log(decodedData);
And it’s still broken:
E-mail zostaý wygenerowany automatycznie, prosimy na niego nie odpowiadaý
Attempt on encoding Resolved/Simple yields:
E-mail zosta�|Ý wygenerowany automatycznie, prosimy na niego nie odpowiada�|Ý
At this point I’m leaning towards a conclusion that this is a bug in the IMAP node, which returns mangled/mojibaked outputs.
Hey @Shalak,
At the moment it doesn’t look like the imap node has support for decoding properly, I will take a look later today and see if this is a quick fix.
Any luck on the quick fix? Is there anything I can do to help?
Hi @Shalak :wave: @Jon is out today, but can post an update on Monday when he’s back :slight_smile:
Hey @Shalak,
I had a quick look and it wasn’t a quick fix as such so I have created an internal dev ticket to set aside some time to look into it.
Hello!
Are there any updates on this one? Is there anything I can do to help?
