Import flow at installation time
I want to install n8n, and when I access it for the first time there is already flow inside, how can I do this?
You can import workflows using the CLI during your installation, so when you open the UI for the first time they’d already be present.
Check out CLI commands | n8n Docs for information on how to do this.
Excellent, thank you very much! and @MutedJam can you help me with my problem Wait does not work after 65 seconds - #3 by krynble
