It’s only max 3800 tokens for each time using ChatGPT 4 preview and we cannot increase it.
But we also cannot reduce the amount of detail that provides to it.
Is there any solution for solving this problem that you experienced?
More specific, the flow is:
- We have to provide detail of business info and campaign direction to the ChatGPT.
- After that, the ChatGPT will read it all then generate social idea posts for us.
So, the output is below 3800 tokens for sure. But the input will be more than that limit, that make the workflow stop to run.
- n8n version: 1.26
- Database (default: SQLite): default
- n8n EXECUTIONS_PROCESS setting (default: own, main): own
- Running n8n via (Docker, npm, n8n cloud, desktop app): npm
- Operating system: win
