Incrementing Node Value Using Custom Scripts
Hi, I have a question. Currently, I have a node that performs a number increment. I am setting this node with an initial value of 0 and want to increment a number in it.
My node component:
Example of my code:
Previously, I used the following, and it worked perfectly:
$item(0).$node["Set counter"].json["counter"]
I’ve tried other ways, such as:
$('Set counter').first().json.counter += 1 // Increment counter
But it didn’t work.
The value is changed, but the state is not maintained. Instead of being altered, it remains at only the value of 1
For the workflow I am working on, this seems to be the only solution. I tried a few others, but they didn’t work. I need to change the value of the node directly using custom node scripts
  • **n8n version: 0.224.2
  • **Database (default: SQLite): postgres
  • **n8n EXECUTIONS_PROCESS setting (default: own, main): default
  • **Running n8n via (Docker, npm, n8n cloud, desktop app): docker
  • **Operating system: Ubuntu Server / docker container
My old code worked, after the update n8n version it didn’t work:
items[0].json.lastNode = false;
$item(0).$node["Set counter"].json["counter"] += 1;
// Check if the current node is the last node
const lastNode = $items("calculate-voucher-quantity", 0, 0).length <= $item(0).$node["Set counter"].json["counter"];
// If it's the last node, set lastNode to true
if (lastNode) {
  items[0].json.lastNode = true;
// Return the items array
return items;
I was able to solve it. :raised_hands::sweat_smile:
I used the variable $runIndex, and the code looked like this:
const isLastNode = $items("node_name_here", 0, 0).length <= $runIndex + 1
items[0].json.lastNode = isLastNode
return items;
Workflow example:
