I have started moving some workflows by exporting from the admin user and importing into a regular user. I manually migrated the auth-data as well. I tested everything from the user-account and it worked.
Some days later I see, that the workflow has stopped.
When I started it from the admin-account, everything was working as expected, so only the regular repeating workflows seem to be broken.
I checked the exections and found this error message (login in as admin)
Failed execution
There was a problem executing the workflow:
“One or more of the used credentials are not accessible.”
Then I wanted to check the workflow and the credentials, when logged in as the regular user, who is owner and creator of this workflow. Then I get another error message (and can’t proceed):
On screen
Init Problem
There was a problem loading init data:
Unauthorized
Browser console:
[Error] Failed to load resource: the server responded with a status of 404 (Not Found) (app.a813abfa.js.map, line 0)
[Error] Failed to load resource: the server responded with a status of 404 (Not Found) (chunk-vendors.bb4d224f.js.map, line 0)
[Error] Failed to load resource: the server responded with a status of 403 (Forbidden) (nodes, line 0)
- n8n version: 0.187.1
- Database you’re using (default: SQLite): SQL (via docker)
- Running n8n with the execution process [own(default), main]: ?
- Running n8n via [Docker, npm, n8n.cloud, desktop app]: Docker
