I am trying to trouble shoot one of my workflows and when I pulled out the following section, it doesn’t work like it does in the original workflow. The node on input 2 is not getting trigged.
Which makes me think I have been using this incorrectly.
@got_flat , try switching to v0 (legacy) execution order in Settings of the workflow. If using v1 logic, you need those node’s input connected to a node that would trigger them.
Hey, @got_flat , I’m not aware of any other ways. If adding extra connections looks messy you always can switch to v0 legacy ordering. I have built many workflows with very complex flows. Using v1 ordering becomes almost impossible without interconnecting the nodes in indeed very messy way. Thus, I often use v0. On the other hand, those connections might help to understand dependencies more clearly and they facilitate execution of the nodes in more effective way with v1 ordering. I just hope that n8n team will not deprecate the legacy v0 ordering. I’m convinced that both have the right to be.
