I’m sure this is a simple thing that I just can’t figure out how to call the keys when they have spaces in the code node. Do I need to use the set node to remove the spaces?
config.json.CoCo Status Column doesn’t work, but I’m not sure what my options are here. Do I need to set the key to CoCoStatusColumn?
Syntax Error
- n8n version:* .233.1
- Running n8n via (n8n cloud):
- Operating system:
