Insert into Supabase Vectorstore is not working
Upload to Supabase is not working
None
  • n8n version: 1.73.1
  • Database (default: SQLite): postgresdb
  • **n8n EXECUTIONS_PROCESS setting (default: own, main):**main
  • **Running n8n via (Docker, npm, n8n cloud, desktop app):**Node.js
  • **Operating system:**AlmaLinux
Hey @Mitchell_Herman , was it workinmg before or it is the first time you are running this workflow? It seems similar to the one explained in https://www.youtube.com/watch?v=ELAxebGmspY. Hopefully it helps.
Delete Supabase and use Postgress Vectore store it works fine
