Inside a loop: use output from outside the loop
I would like to search and upgrade Airtable records. I search them and then start a loop, but for me to upgrade each record, I need the id form the search node, previous to the loop over item one.
The idea is to search item in a table, loop over them, search something related in another table and, if something is found, update the original record.
I don’t know how to use the output from previous node. I tried this:
{{ $('Loop Over Items').first(1, $runIndex -1) }}
But didn’t work.
  • n8n version: 1.39.1
  • Operating system: Ubuntu
hello @giacomolanzi
Try this one. First won’t work.
{{ $('Loop Over Items').last().json.id }}
Thanks, it worked!
