I have just set up n8n using the Kubernetes guide. I am trying to get it working on my own subdomain and I have configured the environment variables as follows:
- name: N8N_PROTOCOL
value: https
- name: N8N_PORT
value: "5678"
- name: N8N_EDITOR_BASE_URL
value: https://n8n.myurl.tld
- name: N8N_HOST
value: n8n.myurl.tld
However I am getting ERR_SSL_PROTOCOL_ERROR and I figure this is because I need to set up the SSL certificate using their respective environment variables.
What I am trying to work out is where to store the SSL certs / how to inject them in to the Kubernetes deployment.
I couldn’t find anything in the docs on this - can anyone point me in the right direction?
Many thanks
Jonathan
- n8n version: Latest version from the Azure setup guide
- Database you’re using (default: SQLite): Postgres
- Running n8n with the execution process [own(default), main]: ?
- Running n8n via [Docker, npm, n8n.cloud, desktop app]: Kubernetes
