Hi all, I am trying to access an API and am having trouble passing an integer value as a body parameter. It seems that the value is not interpreted as an integer. Can you help me with this?
Reagrds René
ERROR: UNKNOWN ERROR - check the detailed error for more information
{ “api_version”: “3.1”, “code”: 422, “message_list”: [ { “details”: { “length”: [ “u’123’ is not of type ‘integer’” ] }, “message”: “Request could not be processed.”, “reason”: “INVALID_REQUEST” } ], “state”: “ERROR” }
Please share the workflow
- Operating System: Windows 10
- n8n version: 0.198.2
- Database you’re using (default: SQLite): default
- Running n8n with the execution process [own(default), main]: default
- Running n8n via [Docker, npm, n8n.cloud, desktop app]: npm
