Any body have any Idea about how can we start a workflow from custom Gpts actions and return sth to the Gtps ?
I mean Like Zappier can we use n8n as well in the custom Gpts?
regards
khashayar
regards
khashayar
Hey @kpakfar,
I have not tried it but looking at the docs you might be able to just create your own OpenAPI file that has your webhook links in it and that might do the job.
It would be great to have the same guide than:
I’ve got Custom GPT’s calling n8n webhooks directly in the ChatGPT interface. You just need to provide a swagger schema and some instructions.
