Integrity automation
I am building a integrity score for an organization. Everything is on clickup, Building dashboards for Individual, Lead, Managers level to check al the tasks completed in a particular day. Now i want a Integrity score (a formula that calcuated % of tasks completed on time) for each individual, Team level and Organization level. Is this possible through n8n? if so can someone help me?
Hey, yes, sounds possible. Here is a general outline of the flow you will need:
  1. Get task data
    -Use the ClickUp → Task → Get Many node.
    -Fetch fields: assignee, status, due_date, date_done (completed date).
    -Apply filters (e.g. only tasks updated today).
  2. Calculate integrity score per task
    Add a Code node:
    return items.map(item => {
      const due = new Date(item.json.due_date);
      const done = new Date(item.json.date_done);
      const onTime = done <= due ? 1 : 0;
      return {
        json: {
          assignee: item.json.assignee?.id,
          team: item.json.assignee?.team_id,
          onTime,
  3. Aggregate scores:
    Use Aggregate (built-in node) or another Code node to group by:
    -Individual (assignee ID)
    -Team
    -Entire org
  4. Build dashboard data
    Push results into Google Sheets, ClickUp custom fields, or a DB (Postgres/MySQL).
General Flow:
  • ClickUp Get Many Tasks
  • Function (mark onTime)
  • Aggregate (by assignee) → produce % completed_on_time
  • Aggregate (by team)
  • Aggregate (all tasks)
  • Push to dashboard DB/Sheet
Let me know if this helps. You can also open threads when you start building it and you face any technical difficulties :slight_smile:
@Kartikeya_Sharma Oh, and if you feel my answer is enough for now, please mark my previous reply as Solution. Follow up questions are welcome of course.
