Hello,
I am encountering an “internal error” problem with the http request node.
The error indicates that it comes from UTF8 encoding but the input data seems to me to be correct (without accent or other…)
When I run this command on Postman, I don’t get any encoding errors.
Do you know where it could come from?
- n8n version: 1.56
- Database (default: SQLite): QLite
- n8n EXECUTIONS_PROCESS setting (default: own, main): main
- Operating system:
