Is Execution Data Pruning On By Default?
Is data pruning on by default? or do i have to enable data pruning the env variable settings?
hello @Andres_Rafael
yes, it’s enabled by default (2 weeks or the last 10k of executions. Which will happen sooner)
Alrighty Thank you for the reply, i appreciate it!
