Hi n8n team,
I’d like to publish a workflow template for free in the official n8n templates library.
Inside the workflow, I’m considering adding a small Sticky Note with promotional lines such as:
- Tailor-made workflow solutions designed specifically for your needs
- Custom n8n node development for your existing workflows
- A fully customized version of this workflow for your needs
Feel free to contact us: [Example Website](example.com)
This would be the only “promo” in the template (no paywall, no selling access to my own n8n instance, just a note that points to my website for optional paid help).
Is this allowed under your guidelines for public templates and the Sustainable Use License? Or should templates remain completely free of any promotional / self‑advertising notes?
I want to make sure my usage is fully compliant before submitting or updating the template.
Thank you!
