Hello,
I would like to try to develop a node, but I would like to use an npm package that requires node 16.
In the n8n documentation I read that I have to use node 14.
So can I only use packages that do not require a version higher than 14? Or is there a way?
Thanks
Sorry, did honestly not try for a while.
You can give it a try and then see what happens or breaks.
