artick
1
Is it possible to scrape Telegram Group Admins with the Telegram Node?
If yes can you send a guide or a json of the solution
Hi @artick
I think there is no way we can do that with the Telegram Node.
Not related to n8n, You can check Telethon for this use case.
artick
3
@mcnaveen Are you sure itβs not possible?
Integromat is doing it
Hey @artick
As per the Telegram Documentation, the Bot has to be the Administrator of the Group or Channel to get the Administrators details.
I added this functionality to the Telegram Node. Hopefully, someone from the n8n team will merge it soon.
Update:
jan
5
Got released with [email protected]
