so I want to input the partner_id value in the form of an integer. when the test node is successful. but the partner_id data is not saved as integer and when I search, the data stored in partner_id instead changes to boolean.
partner_id: false.
It is possible that the input provided does not match the format or data type expected by Odoo.
What I want to ask is whether I am doing the input wrong?
is there a better way?
there is no error. because node is success.
expected result
reality result
input to node
- n8n version:
- Database (default: SQLite):
- Operating system:
