Hello everyone, I have an issue: after logging in from different browsers, the n8n UI theme is light mode, and I want to set it to dark mode by default (as shown in the image below).
Is there a related environment variable or a better method? Thanks in advance!
hello @kevin
The default theme is system, which means the theme would be the same as in your browser/OS.
There is not much sense in having a separate variable for that, as it’s a one-time action.
