Is there a way to hide a spreadsheet's tabs?
Hi @noobsaibot,
Tip for sharing your workflow in the forum
Pasting your n8n workflow
<your workflow>
Make sure that you’ve removed any sensitive information from your workflow and include dummy data or pinned data as much as you can!
Judging by the UI, I’m assuming that you’re trying to hide a Sheet in the Google Sheet’s UI?
If you’re creating a new sheet in a Google spreadsheet that you want to hide from the UI, you can do this by turning on the ‘Hidden’ option in the Google Sheet node:
If you want to hide a sheet that’s already been created, the current Google sheet node doesn’t support this but you can make a custom API call using the HTTP request node like so:
Hope that helps!
