There is a cli tool but I have not used it yet and I am not sure what you can pass / return.
What I would do is pipe it out to a curl command and use a web trigger in n8n that way you can use the same workflow with anything that can make an HTTP request.
Yes @Jon is correct. Best to do it with curl and Webhook Node. We would need a special Trigger node for it. You can create a Feature request to make it work in the future.
