Is there any way, to pin and unpin multiple nodes?
Hey @Emin_Laz
yes select all you want and push the p button on keyboard. (it will need data there to pin bear in mind)
Samuel
@King_Samuel_David beat me to the answer, but you can find most shortcuts from the dot menu on a node. Another useful shortcut is to activate/deactivate multiple nodes etc
Even better @Wouter_Nigrini :slight_smile: hope everything going well :slight_smile:
Thank you!!
Thank you!
