Hi dear @jan
according below image:
As you see reference that system make it is wrong and the result is not found.
I myself test some Expressions and found that there are valid one.
You think it is because of my mistake or for system issue .
Best regards
jan
2
Thanks a lot. That looks like a bug. I will add it to my list.
you’re welcome.
You are a good man.
jan
4
Sorry forgot to update here. Got fixed in the meantime. So if you update to the latest version it will work.
