Issue in parsing tawk.to data on webhook
"headers":{
"host":"flow.ourklient.com",
"user-agent":"tawk.to-webhook",
"content-length":"490",
"content-type":"application/json",
"x-forwarded-for":"35.232.27.218",
"x-forwarded-host":"flow.ourklient.com",
"x-forwarded-port":"443",
"x-forwarded-proto":"https",
"x-forwarded-server":"c8aad5ad9548",
"x-hook-event-id":"8024483584994071",
"x-real-ip":"35.232.27.218",
"x-tawk-signature":"76842eb30acfa87009d8f88c7b2f776ae53b6a23",
"accept-encoding":"gzip"
"params":{
"query":{
"body":{
"chatId":"86a39470-24b2-11ee-9558-41699ded48d3",
"visitor":{
"name":"chandan kumar gupta",
"city":"delhi",
"country":"IN",
"email":"[email protected]"
"message":{
"sender":{
"type":"visitor"
"text":"Name : chandan kumar gupta Mobile No. : xxxxx Email : [email protected] Course or Services inquiring for? : testing webhook api for tawk to",
"type":"msg"
"time":"2023-07-17T14:59:58.029Z",
"event":"chat:start",
"property":{
"id":"5afe76eb5f7cdf4f053453ee",
"name":"DIDM"
i am trying to get Name, Emai, Phone from this, Name & Email is easily coming out by set node, But getting Phone Number is challenge to me any code or node to get this phone number
Hey @chandan988,
The best option would be to use a regular expression to get the data you are after. The ugliest way I can think of that would do it without Regex would be {{ $json.body.message.text.split('Mobile No. :')[1].split('Email')[0].trim() }} which you can see in action in the workflow below.
this is correct, But i cannot use previous data to run it automatically basically i cannot drag webhook header into this Function node so it runs automatically any solution to put previous webhook node data ( Header ) to this function node
Hey @chandan988,
I don’t follow, Why can’t you use previous data? The example does just that.
