I have created a custom node that is supposed to read a JSON Array. But n8n is appending something like [Array: ] at the beginning because of which it’s erroring out as in my node I am doing JSON.parse() to read the data.
Tried several methods, including removing the Array: part using JS slice method and then parsing. Nothing seems to work.
Please share the workflow
(Select the nodes and use the keyboard shortcuts CMD+C/CTRL+C and CMD+V/CTRL+V to copy and paste the workflow respectively)
- n8n version:
- Database you’re using (default: SQLite):
- Running n8n with the execution process [own(default), main]:
- Running n8n via [Docker, npm, n8n.cloud, desktop app]:
