{n8n cloud - Version 1.31.2}
I was trying to list bucket’s objects by using AWS S3 node and got that error when i was testing the connection
{ERROR: Forbidden - perhaps check your credentials?
403 }
and i am totally sure that the tested credentials are working perfectly because i have tried them several times in other frameworks,
later i found another s3 node , so i tried it , it worked fine in only two operations , in listing all buckets and bucket creation , but when i try to use it in any other operation like bucket’s objects retrieval i got that error {Cannot read properties of undefined (reading ‘_’)}
also i thought about using http request in hitting s3 , so i used in http node predefined credential with type AWS to achieve that , but also it didn’t work and i got that error
ERROR: Bad request - please check your parameters
400 - “InvalidArgumentHttp Request has no x-amz-content-sha256 header or it has a blank
amz-content-sha256” - InvalidArgument Http Request has no x-amz-content-sha256 header or it has a blank
