Issue in workflow execution and trigger
Hey everyone,
I am having issue with my workflow execution,
I am currently in testing mode, and when I click the ‘Test Step’ button on my ‘AI-Agent’ node, a pop-up appears saying ‘Workflow executed successfully,’ but no output is displayed.
Any help will be appreciated.
please find below the screenshots for 1st issue.
Welcome to the community @Mayank_Nagariya !
Tip for sharing information
Pasting your n8n workflow
<your workflow>
I looks like it couldn’t infer the actual input if you have it added to your prompt using an expressions to link to the text in IF node (or whatever node that is). This could happen with branching such as the one resulted by utilizing IF node, Switch, etc.
