Hey folks,
I’m struggling to work out how to return my data from a code node. I’ve tried returning inside a function (doesn’t return) and doing a push() to a varable outside then returning (remains empty). I can console.log() the data absolutely fine though.
Use case it getting data via httpntlm, as it’s not currently supported by n8n HTTP Request.
let httpntlm = require('httpntlm');
let output = [];
httpntlm.get({
url: 'https://exampleendpoint/api/data/v9.0/',
username: 'whatever',
password: 'watever',
workstation: '',
domain: ''
}, function (err, res){
if(err) return console.log(err);
let resBody = res.body;
console.log(resBody); //Console log works perfectly
return resBody; //Cant return data here for some reason, even if in array.
output.push(resBody); //Cant push data to output array
return output; //This is empty
// Example of data in console log
"@odata.context":"https://exampleendpoint/api/data/v9.0/$metadata",
"value":[
{"name":"whatevercollection","kind":"EntitySet","url":"whatevercollection"}
{"name":"accounts","kind":"EntitySet","url":"accounts"},
{"name":"aciviewmappers","kind":"EntitySet","url":"aciviewmappers"},
- n8n version: 1.81.4
- Database SQLite
- Running n8n via npm
- Operating system: MacOS
