Hi to all,
I am running into a problem when using the “Set Custom Fields” node in ClickUp. I need to insert a numeric value (the ID of the bound folder) into a custom field of type Text.
Error description:
When I try to insert a numeric value, I get an error
Tried adding toString() to the value but the result is the same.
Interestingly, when I write just numbers in this field, I get the same error. However, if you add at least one character (such as comma, quotation mark, etc.), the value is passed successfully.
Obviously, I need to convert the numeric value to a String somehow, but I can’t find the right approach.
Additionally:
When I change the type of the custom field to Number, the value is passed, but in a dotted format (eg “901.213.664.19”), which also doesn’t work.
Any advice and solutions would be greatly appreciated!
Thank you!
Value is not a valid string
