Issue when uploading gmail attachment to onedrive
I have a problem when trying to upload a gmail attachment to onedrive
Problematic node
the same issue with attachment_0.data
When I tried to upload a file without the binary flag, the file was uploaded, but it was corrupted.
  • n8n version:1.15.2
  • Running n8n via: npm
  • Operating system: ubuntu
Update:
This is also interesting:
Gmail attachment is not binary? :thinking:
Another update, this scenario with saving the file to disk works :thinking:
So I can solve my problem with a workaround, with saving the data to disk
Hey @migellal,
Annoyingly in n8n binary data can only be used from the node before the node you are running so if the Create Folder node doesn’t output the binary item it won’t be in the Upload File node. To get around this you would need to use a merge node from the Code node and the Create Folder node to bring the binary data forward.
