Issues Accessing SharePoint Subfolders
I’m trying to access a specific folder in SharePoint using n8n, but I’m encountering various error messages. I hope someone has experience with this issue and can help me.
What I’m Trying to Achieve
I want to access the following SharePoint folder:
https://mycompany.sharepoint.com/sites/FE/FEDE/02_Intern/10_Test AI_Automation
Error Messages and Previous Attempts
Attempt 1: Standard SharePoint API Path
First, I tried to access using the standard path:
https://mycompany.sharepoint.com/_api/Web/GetFolderByServerRelativePath(decodedurl='/sites/FE/FEDE/02_Intern/10_Test AI_Automation')
Error Message: 404 - “The resource you are requesting could not be found”
{"error":{"code":"-2147024894, System.IO.FileNotFoundException","message":{"lang":"de-DE","value":"Datei nicht gefunden."}}}
Attempt 2: Direct API Access to the Subsite
Then I tried to access the subsite directly:
https://mycompany.sharepoint.com/sites/FE/FEDE/_api/web/lists
Error Message: 403 - “Forbidden - perhaps check your credentials?”
{"error":{"code":"-2147024891, System.UnauthorizedAccessException","message":{"lang":"","value":"Access is denied. (Exception from HRESULT: 0x80070005 (E_ACCESSDENIED))"}}}
Attempt 3: Various API Variants
I tried different API path variants:
/GetFolderByServerRelativeUrlinstead of/GetFolderByServerRelativePath- Different URL encodings for spaces and special characters
- Requests to base folders to understand the structure
All of these attempts resulted in either 404 or 403 errors.
Configuration and Permissions
In Microsoft Azure, I have configured the following Graph API permissions:
- Files.Read.All
- Files.ReadWrite.All
- Files.ReadWrite.AppFolder
- Sites.FullControl.All
- Sites.Manage.All
- Sites.Read.All
- Sites.ReadWrite.All
- Sites.Selected
- User.Read
- User.ReadBasic.All
These permissions show as “Granted for MyCompany” in Azure.
Questions
- How can I correctly access the subfolder in a SharePoint subsite via n8n?
- Is my API path format correct, or is there a different syntax for subsites?
- Could there be an issue with the authentication method, even though I have all the necessary permissions?
- Should I use the Microsoft Graph connector instead of the SharePoint HTTP Request? If so, what would be the correct access path?
I appreciate any help or suggestions. Thank you in advance!
