Issue with creating yoast meta description for Wordpress Blog
I have a workflow that uses Open AI to create a blog post and a featured image in Wordpress. Works well. Now I need to add a focus seo keyword and meta description, both generated in the workflow.
I can use the MySQL node to edit the meta description and / or the focus keyword for the post in the database. But for new posts those meta keys don’t yet exist. If I edit them in Wordpress post editor first, I can then update them with new values. That’s is obviously of little value as I want to create them via the n8n workflow
How can I create the meta keys
_yoast_wpseo_focuskw
_yoast_wpseo_metadesc
for a brand new post and then populate them with the data form the work flow.
I assume the answer would be a MySQL query?
Here is the portion of the workflow that successfully edits the meta keys if they are pre-existing
I answered my own question
INSERT INTO wp_postmeta (post_id, meta_key, meta_value)
VALUES (your_post_id, '_yoast_wpseo_metadesc', 'your_meta_description');;
That creates the row and adds in meta description.
