Hi everyone,
I’m facing a challenge with my workflow in n8n and would appreciate any help.
In my workflow, Twilio sends me a message, to which I reply with a specific trigger word. This response then triggers the first webhook. However, the webhook doesn’t have access to the information from previous steps. This issue also occurs with the second webhook.
I need the flow to retain the context of the previous data after each webhook is triggered—specifically, the email content and the initial draft created in the first flow. OpenAI should be able to access this information in the next step to adjust my response accordingly.
Is there a way to configure the workflow so that the webhooks can access information from the initial flow, preserving context between them?
Thanks a lot for your help!
