Hi,
I can’t create ftp credential.
Credential workin with filezilla (FTP, not SFTP)
- n8n version: latest
- Database (default: SQLite): postgre
- Running n8n via (Docker, npm, n8n cloud, desktop app): docker
- Operating system: ubuntu22
filezilla debug :
Suivi : CRealControlSocket::DoClose(66)
Suivi : CControlSocket::DoClose(66)
Suivi : CFtpControlSocket::ResetOperation(66)
Suivi : CControlSocket::ResetOperation(66)
Suivi : CFileZillaEnginePrivate::ResetOperation(66)
Suivi : CFileZillaEnginePrivate::ResetOperation(0)
Suivi : CControlSocket::SendNextCommand()
Suivi : CFtpLogonOpData::Send() in state 0
Statut : Résolution de l’adresse de ftp.********.com
Statut : Connexion à *************:21…
Statut : Connexion établie, attente du message d’accueil…
Suivi : CFtpControlSocket::OnReceive()
Réponse : 220-FileZilla Server 1.7.3
Réponse : 220 Please visit https://filezilla-project.org/
Suivi : CFtpLogonOpData::ParseResponse() in state 1
Suivi : CFtpLogonOpData::Send() in state 2
Commande : AUTH TLS
Réponse : 234 Using authentication type TLS.
Suivi : CFtpLogonOpData::ParseResponse() in state 2
Statut : Initialisation de TLS…
Suivi : tls_layer_impl::client_handshake()
Suivi : tls_layer_impl::continue_handshake()
Suivi : TLS handshakep: About to send CLIENT HELLO
Suivi : TLS handshakep: Sent CLIENT HELLO
Suivi : tls_layer_impl::on_send()
Suivi : tls_layer_impl::on_read()
Suivi : TLS handshakep: Received SERVER HELLO
Suivi : TLS handshakep: Processed SERVER HELLO
Suivi : TLS handshakep: Received ENCRYPTED EXTENSIONS
Suivi : TLS handshakep: Processed ENCRYPTED EXTENSIONS
Suivi : TLS handshakep: Received CERTIFICATE
Suivi : TLS handshakep: Processed CERTIFICATE
Suivi : TLS handshakep: Received CERTIFICATE VERIFY
Suivi : TLS handshakep: Processed CERTIFICATE VERIFY
Suivi : TLS handshakep: Received FINISHED
Suivi : TLS handshakep: Processed FINISHED
Suivi : TLS handshakep: About to send FINISHED
Suivi : TLS handshakep: Sent FINISHED
Suivi : TLS Handshake successful
Suivi : Protocol: TLS1.3, Key exchange: E**HE-SEC***4R1-***SA-SEC**56R1-SHA256, Cipher: AES-256-GCM, MAC: AEAD, ALPN: x-filezilla-ftp
Suivi : tls_layer_impl::verify_certificate()
Suivi : System trust store decision: true
Suivi : Sending certificate_verification_event
Suivi : CFtpControlSocket::SetAsyncRequestReply
Suivi : set_verification_result(true)
Statut : Connexion TLS établie.
Suivi : CFtpLogonOpData::Send() in state 6
Commande : USER *******
Réponse : 331 Please, specify the password.
Suivi : CFtpLogonOpData::ParseResponse() in state 6
Commande : PASS ********************************
Réponse : 230 Login successful.
Statut : Connecté
Suivi : Measured latency of 26 ms
Suivi : CFtpControlSocket::ResetOperation(0)
Suivi : CControlSocket::ResetOperation(0)
Suivi : CFtpLogonOpData::Reset(0) in state 15
Suivi : CFtpListOpData::Send() in state 0
Statut : Récupération du contenu du dossier…
Suivi : CFtpChangeDirOpData::Send() in state 0
Suivi : CFtpChangeDirOpData::Send() in state 1
Commande : PWD
Réponse : 257 "/" is current directory.
Suivi : CFtpChangeDirOpData::ParseResponse() in state 1
Suivi : CFtpChangeDirOpData::Reset(0) in state 1
Suivi : CFtpListOpData::SubcommandResult(0) in state 1
Suivi : CFtpListOpData::Send() in state 2
Suivi : CFtpListOpData::Reset(0) in state 2
Statut : Contenu du dossier « / » affiché avec succès
