Hi
I am using n8n docker and i tring to connect my GitLab to Ai Agent no
“The resource you are requesting could not be found” No matter what mapping I change on Project Owner , or Project Name or Path i get this error “**The resource you are requesting could not be found” i check with CURL and it work fine
the url i tested “https://gitlab.test.com/api/v4/projects/5768/repository”
on the node gitlab url it past the check with https://gitlab.test.com/api/ also https://gitlab.test.com
Has anyone had a similar problem?
Thanks
