Issue with JSON structure/syntax
My JSON contains data, appears to be correct, however when I am trying to use it using javascript, it is simply returning [object object] istead of real data which is causing systax error while loading it into MongoDB through API.
Please refer to the screenshot:
400 - “"Invalid syntax error: TypeError: invalid character ‘o’ looking for beginning of value"”
  • n8n version: 1.32.1
  • Running n8n via (Docker, npm, n8n cloud, desktop app): n8n Cloud
This solved the problem.
Thanks!
