We have created a new LinkedIn app using the community management api product and have gone through the steps to get it approved by Microsoft/LinkedIn for the Development Tier. Please see the screenshots below. The scopes include rw_organization_admin which is required to access the organizationalEntityFollowerStatistics endpoint to retrieve lifetime follower information:
When using the http request node in n8n for the LinkedIn Community Management OAuth2 API Credential Type only 3 scopes are shown as available:
w_member_social
w_organization_social
r_basicprofile
This is even before selecting the created credential in n8n and remains the same after selecting it. When executing the request (https://api.linkedin.com/rest/organizationalEntityFollowerStatistics?q=organizationalEntity&organizationalEntity=urn:li:organization:{organization ID}) - the following 403 error is returned
Please note the {organization ID} above actually contains our company 8 digit org id. I did not include it above.
403 - "{\"status\":403,\"serviceErrorCode\":100,\"code\":\"ACCESS_DENIED\",\"message\":\"Not enough permissions to access: partnerApiOrganizationalEntityFollowerStatistics.FINDER-organizationalEntity.20240901\"}"
The LinkedIn-Version parameter is passed in the header and I can successfully use the Community Management OAuth2 credentials to use the administered organization lookup
https://api.linkedin.com/rest/organizations/{organization ID}
Am I missing a step here? Authentication works fine, but the limited scopes in n8n seems to be an issue. Thank you for your help.
**n8n version: 1.61.0 (cloud)
**Database (default: SQLite): default
**n8n EXECUTIONS_PROCESS setting (default: own, main):
**Running n8n via (Docker, npm, n8n cloud, desktop app): n8n cloud
**Operating system:
