I have this workflow running live on production. It works pretty well. BUT when I want to inspect an execution to make some improvements and I want to inspect a request node to see which data it used, I get this No data found for item-index: “0” error.
But the node did actually run succesfully, and it processed the correct data. So it seems that the data is mapped correctly, but just not visible in an execution.
I have seen that sort of thing happen when you have 2 nodes going into one node, The editor can sometimes get confused as it doesn’t know which of the nodes to get the data from to display. There isn’t really a pretty way to solve that at the moment but I will check to see if we already have a bug ticket open for that.
This issue is also not likely to be linked to the one you are seeing in the ticket you opened.
Ok thanks for the response, Jon. I see your point regarding connect 2 nodes to 1 node. However, this problem occurs in a node with a single connection, in this workflow, as well.
The code node doesn’t support the .item option, instead you might need to use .all() then loop over those items as needed. You can find the different options for this here: Output of other nodes | n8n Docs
In the Code-Node, the best thing to use would be the following syntax, where you can supply the index of the item. It will make sure that it uses the pairedItem information to resolve correctly:
